This appears to be impossible to achieve without using 3rd party software (Lexicon) - and every time I add new tracks to my VDJ database, I have to export the database to Lexicon again, and it really does not like my filters/folders/playlists - but seems very hit and miss on what it decides to copy across and what it decides is no longer valid.
But is the problem with VDJ or Lexicon? Who knows... but if we had the option to export directly from VDJ to Engine DJ that would cut out one possible error point.
geposted 3 hours ago
I just maintain VDJ and Engine databases separately, however it would be better to have a one click solution.
I've worked out a way to transfer VDJ playlists to Engine using iTunes but again it's quite convaluted.
Is that a fair request, really? What other DJ software can export in the competitor's DB formats?
All the DJ programs are designed the same way, to import (once) from whatever you used previously in to their system and then stay with their program.
I was going to say the same thing as Keith - are you really adding so many tracks each time that it's impractical to update VDJ and Engine separately?
