Hello,
I want to use this action and apply it on al decks. This action don`t work.
What is the correct syntaxx?
gr. Marcel
<button action="toggle '@$xxx7' && deck all repeat_song">
<pos x="+750" y="+17"/>
<size width="360" height="50"/>
</button>
gr. Marcel
geposted Sat 18 Apr 26 @ 1:38 pm
<button action="toggle '@$xxx7' & deck all repeat_song">
</button>
</button>
Try these two and see if they solve your problem.
geposted Fri 08 May 26 @ 4:44 pm
The action repeat_song is a toggle, meaning that if enabled on deck 1 but disabled on deck 2, pressing the button will disable on Deck 1 and enable on Deck 2.
If you want to make sure all Decks are on/off at the same time, you can have ..
And not sure what the toggle variable is for, perhaps not needed if your issue is the above? Perhaps ...
to get the button light up (assuming you have <on>/<off> graphics
action="deck 1 repeat_song ? deck all repeat_song off : deck all repeat_song on"
action="deck 1 repeat_song ? deck all repeat_song off : deck all repeat_song on" query="deck 1 repeat_song"
geposted Fri 08 May 26 @ 5:36 pm
