If i have a file with filename "Spritney Bears - Oops I Did It Again ( 95bpm) .mp3 . and want to get rid of the "( 95bpm)" i can search for (*) and delete that part of the filename but then i will lose the history with 3 party software, Is there a way to do it in batch, i can fix it manually, but there are a lot of songs to fix
geposted Sat 25 Apr 26 @ 10:01 am
1) You should rename the files from within VirtualDJ.
2) The built in Tag Editor allows you to select a batch of tracks and batch rename them to "Artist - Title" which seems to be exactly what you want..
geposted Sat 25 Apr 26 @ 11:15 am
