Howdy!
I'd really like the ability to smoothly transition from one key to another whilst keeping the tempo of the track unchanged, I don't believe this is currently available, i may well be wrong though!
I know you can move smoothly through the keys by taking off master tempo and pitch shifting, but that obviously changes the tempo.
That'd be cool if can be done
geposted Wed 06 May 26 @ 10:55 am
You can, key_smooth will move cents over a range of -6/+6 notes on a 0.0-1.0 dial.
Easier on an encoder, possible with a regular dial but the script is involved to be done right.
As a rsi, possible, depends on how dynamic you want it, single custom button one trick for a known transition, all the way to pad page with dialling in key & duration, it's all possible.
*edit, actually for encoders or rsi, key_move +0.0X would be easier.
geposted Wed 06 May 26 @ 11:42 am
ahh right, nice!! Thanks i will look into that.
geposted Wed 06 May 26 @ 12:59 pm
Is this key_smooth able to reset the key smoothly? like the pitch_reset does. I can achieve increase and decrease smoothly but am looking for a smooth reset solution to be added to a custom button.
geposted Tue 19 May 26 @ 11:55 am
param_bigger 0.5 `key_smooth full` ? repeat_start_instant keyMover 100ms -1 & param_smaller 0.501 `key_smooth full` ? key_smooth full 0.5 & repeat_stop keyMover : key_smooth full -0.01 : param_smaller 0.5 key_smooth full ? repeat_start_instant keyMover 100ms -1 & param_bigger 0.499 `key_smooth full` ? key_smooth full 0.5 & repeat_stop keyMover : key_smooth full +0.01 :
like that.
geposted Tue 19 May 26 @ 1:16 pm
Yes, exactly like that!! That's awesome, thanks. I'll ping some beer tokens your way 😃
geposted Tue 19 May 26 @ 3:08 pm
Beer? My favourite, Thanks :)
geposted Tue 19 May 26 @ 3:29 pm
I tweaked it slightly from 0.01 to 0.001, it works nicely for my needs. Might be a bit niche but definitely useful.
geposted Tue 19 May 26 @ 5:55 pm
