Was using VDJ 2026 (part 1) on a MacBook Pro M3 during a gig and needed to switch wifi signals (because the venue wifi was weak) and VDJ crashed and restarted. Not the Mac, just VDJ. I have since updated to 2026 (part 2). Is switching wifi a known crash trigger? If you'd like more details or event log info, let me know what and how to send.
geposted 2 hours ago
That shouldn't be a crash trigger by itself.
Could you describe what you were doing at the time in VirtualDJ (any specific task, controllers or remote connected, etc)?
I've personally experienced a crash before when using the VirtualDJ Remote from a hotspot connection on my phone, and then essentially disconnecting the hotspot. That was a couple years ago though and I've never done that sequence since to see if the situation changed.
geposted 56 minutes ago
