Hello , I am trying to see if there is an automatic way to create playlists in virtual dj form my folders on my Macbook. I am playing music directly from my folders, but I want to create playlists inside virtual dj so I can transfer my virtual dj tags to rekordbox for usb export through some programs.
So I've seen that maybe I can do that with a filter, but I dont know how, can anyone help me?
I want the lists (If possible) to be updated automatically as I add songs to my collection . I have all my music in one folder (with subfolders inside), ideally if its just a simple order with a file path of that folder?
geposted Fri 29 May 26 @ 4:01 pm
In VDJ, a list is a collection of “links” to tracks. If you move the track (inside VDJ) or rename it, the list is updated.
If you want something that is dynamically updated, then you need a filter folder and not a list folder.
But I'm unsure that it's compatible with your export need.
geposted Sun 28 Jun 26 @ 2:16 pm
