when i am trying to copy or move a track (s) to an external drive from within vdj , it does not show up in the copy window.
only the drive where the track is located shows.
Windows 11, vdj 2026 b9336
I tried re-installing vdj but no luck
thanks for any help.
geposted 2 hours ago
It should definately show more elements there..
I don't remember if there was a difference, but is there any chance you have downloaded (and installed) VirtualDJ from Windows Store instead of this website ?
Edit:
And the user account you're using on Windows has Administrator rights, right ?
Edit:
no, directly from here.
i dont have this issue on my other laptops.
only on my desktop.
could it be because i am not logged in ?
i cant see how this could affect it..
only on my desktop.
shall i delete the settings (or back it up) and start again with the settings ?
nope...did not fix it
still opens up only the location the file is & the user folder...
no other drives
it happened before and i can not remember what i did...i fixed it then...
no other drives
