Dear VDJ team,
In the past, I purchased VDJ Pro, and after an upgrade, I noticed that my license had expired. Yesterday, I bought a new license for a year and thought this would solve the problem. However, when starting up, I still see a pop-up in the bottom right corner of the screen stating that it is a demo that is valid for another 28 days. Can you explain to me why I still have a demo?
I have a registered account both on the website and in VDJ software. The DJ controller is a Numark Mix Track Pro, and it works properly.
Kind regards
Kind regards
geposted 3 hours ago
You only appear to have a VirtualDJ Home Yearly subscription on that account, not a pro license.
So you still have 29 days of Pro Demo, after which you can continue using it with the Home license you purchased.
Thank you for the quick reply.
After the upgrade, I did indeed receive the Pro version. Does this mean that after 29 days it will switch to the Home version under my new license?
