when i execute the below shortcut mapping,vdj freezes randomly
deck 1 slip momentarily & down ? deck 1 goto +0.15 momentarily & deck 1 loop 0.5 & deck 1 effect_active "KeyLoopUp" on & effect_list 3 "Legacy" & deck 1 effect_select 3 "Backspin" & deck 1 effect_active "Backspin" on & deck 1 effect_slider "Reverb" 1 50% & deck 1 effect_slider "Reverb" 2 50% & deck 1 effect_slider "Reverb" 3 50% & deck 1 effect_slider "Reverb" 4 50% & deck 1 effect_button "Reverb" 1 on & deck 1 effect_button "Reverb" 2 on & deck 1 effect_active "Reverb" on & deck 1 gain -10% momentarily : deck 1 effect_active "KeyLoopUp" off & deck 1 effect_active "backspin" off & deck 1 loop_exit & deck 1 effect_active "Reverb" off & deck 1 goto -0.15 & deck 1 gain +10% momentarily & effect_list 3 "Default" & deck 1 effect_select 3 "Slipbrake8"
geposted 2 hours ago
deck 1 down ? slip on & goto +0.15 & loop 0.5 & effect_active "KeyLoopUp" on & effect_active "Backspin" on & effect_slider "Reverb" 1 50% & effect_slider "Reverb" 2 50% & effect_slider "Reverb" 3 50% & effect_slider "Reverb" 4 50% & effect_button "Reverb" 1 on & effect_button "Reverb" 2 on & effect_active "Reverb" on & gain -10% : goto -0.15 & slip off & effect_active "KeyLoopUp" off & effect_active "backspin" off & loop_exit & effect_active "Reverb" off & gain +11%
That's most of the fluff removed
geposted an hour ago
does not work as desired..when u have time on your hands..plug in both scripts and see
geposted 50 minutes ago
