Hallochs together. First of all, praise for the great program! I am a beginner in dj-ing and currently only have your software to mix. Now I noticed that you play after the track, when the bass plays, always has problems with the mouse to turn the controls! My suggestion would be to have a button on each side of the bass controls where, after confirmation, if you turn one, the other turns opposite. Something like that would help not to make mistakes if you slip off with the mouse, for example! Greetings to your team
geposted Tue 16 Jun 26 @ 10:08 am
You could use the crossfader instead.
geposted Tue 16 Jun 26 @ 11:14 am
There are also eq_crossfader_high, eq_crossfader_mid and eq_crossfader_low actions.
geposted Tue 16 Jun 26 @ 12:05 pm
Thanks for the answers. Yes, I have tested it and with the crossfader it sounds different than with the normal controls! I will try to change and practice. But where can I find the crossfader settings for eq _ crossfader _ high-low? Thank you
geposted Tue 16 Jun 26 @ 12:29 pm
