Topic: Do I need a controller for this?
Hallochs together. First of all, praise for the great program! I have a question. I noticed in a techno mix that when the next tracks are recorded the bass doesn't change, the tracks go seamlessly into the next ones. Now my question, do I need a controller for this? Greetings
geposted Tue 16 Jun 26 @ 10:22 am
No, but.. yes!
I mean technically you don't need a controller. You can achieve the same result with keyboard and mouse.
However, using a controller makes the whole process a million times easier. To the point that yes, you need a controller! :)
Thank you for the answer. Yes, I already thought but how much should you spend on a controller to have a good sound result, is one enough for 300 €? Greetings
In fact, any controller that is equiped with a Filter knob (HP/LP). Then you are able to cut the lows and keep your transitions between tracks much smoother.. But a tone control would also come in handy.. in case tracks seem to consist of more bass or highs..
I sometimes use a Hercules DJ Control Mix Ultra, if space is limited. (using a separated soundcard). But there's even a cheaper Numark which offers a separate headphone output. So you are able to monitor a track (listen to it without playing it on the main outputs) while you press play and time-shift it, if desired -The old-skool method-. Or altenatively you could use the 'Sync' shortcut which about any controller offers. -The easy way-.
https://www.numark.com/product/party-mix-ii
Any controller is well spend money and fun either way. :-)
Ok cool thanks for the tip. Greetings
