Topic: controller button assign
Hi,
Is there a way to assign a controller button to work solely on the controller it is pressed on?
I have two controllers the same and when some buttons are pressed they affect both controllers, which is fine. However I'm looking to modify a button or two so it only works on the controller it is pressed on, not both. I have looked at controller assign but it doesn't appear to do what I need.
Is there something else I can try?
Thanks
Bryn
geposted 4 hours ago
You'll have to be more specific about what you want these buttons to do.
If they change a VDJ setting, then that will indeed affect both controllers, and you'd need to change the mapping of the affected functionality in both controllers to have a different behavior.
