Topic: Horizontal wave display stutters !
Which settings affect the horizontal wave display?
I have a very weak PC, yet the waveform display doesn't stutter
and the waveform display stutters on my high-performance PC
geposted Wed 15 Jul 26 @ 3:06 pm
Skin FPS. I have my ones set as 60 and it's pretty smooth. Also check which graphics card VDJ is using for the skin if you have more than one. Setting is skinuselowpowergpu
Thanks @KRADCLIFFE
On both PCs, all the FPS is set to 60 and skinUse is set to High Power
but the high-performance one stutters !
Are there any other settings that affect the waveform display?
Try low power and see what happens. I generally use the on chip graphics for the skin, video out and the dedicated graphics for stems.
Also check the relevant card control panel and turn off all the blurb you don't need.
Same issue for me. I keep getting issues with virtual dj lately. Im so sick of it.
Same Issue for me. Anyone solve this?
My Laptop Specs:
Processor Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz (2.59 GHz)
Installed RAM 32.0 GB (31.8 GB usable)
Graphics card NVIDIA GeForce RTX 2080 Super with Max-Q Design (8 GB)
Intel(R) UHD Graphics (128 MB)
Storage 826 GB of 1.40 TB used
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
