Is there a way to set the vocal remover stem to say 50% or have a variable 0 to 100% vocal cut?
geposted Wed 22 Jul 26 @ 6:09 pm
that would be just positioning the stem slider
stem vocal 0.5 ? & stem vocal 0.15 : stem vocal 0.5
geposted Wed 22 Jul 26 @ 6:28 pm
Yes. The vocal remover is controlled by the Vocal stem level.
Just note that `50%` is the normal vocal level, and `0%` is fully removed. So a 50% vocal cut would be around `25%`:
For a button that toggles between normal and partially removed:
For a knob or slider that gives you a full 0–100% vocal-cut range, use:
At one end the vocal is normal, and at the other end it is fully removed.
stem "Vocal" 25%
stem "Vocal" 50% ? stem "Vocal" 25% : stem "Vocal" 50%
param_invert & param_multiply 50% & stem "Vocal"
geposted Thu 23 Jul 26 @ 10:17 pm
You can also control the Stems via the Equalizer Potis .
When You change the Equalizer Mode to Stems ect.
geposted Fri 24 Jul 26 @ 6:04 pm
LocoDog where is the stem slider in the pro layout? I don't see one available.
geposted 4 days ago @ 10:40 pm
