I have virtual dj hercules console. Also Win 98/Celeron 2.2.
The program loads off the disc OK but when I double click the icon I get
Illegal operation, invalid page fault virtualdj_djc_.exe at 0187:00423aca
Any ideas?
John
Any ideas?
John
geposted Mon 01 Dec 03 @ 1:28 pm
How many Ram did you have ?
geposted Mon 01 Dec 03 @ 4:02 pm
Hi
The system is 4 months old. Windows 98 was fresh loaded onto a newly formatted disc last week. Both CD Creator 5 and Tractor DJ/Studio run OK. It is a Celeron 2.2 desktop with 512Mb memory and 2 big discs.
I loaded the Hercules code update, it updated the database and came up with this fault.
VIRTUALDJ_DJC caused an invalid page fault in
module VIRTUALDJ_DJC.EXE at 0167:00431f8a.
Registers:
EAX=00000000 CS=0167 EIP=00431f8a EFLGS=00010206
EBX=0094f9d8 SS=016f ESP=0094f734 EBP=0094f9a4
ECX=c1ac0f10 DS=016f ESI=005ef9e0 FS=37af
EDX=0001004c ES=016f EDI=00000000 GS=0000
Bytes at CS:EIP:
8b 48 08 8b 50 04 51 8b 48 10 52 8b 50 0c 51 52
Stack dump:
00000788 00541cf0 0042b758 00541cf0 00000001 0000ffff 01240000 19270000 04000004 05970010 00000000 00000000 00000000 fffffffa 00000000
The standard trial version also fails in a similar way.
Regards
John
Registers:
Bytes at CS:EIP:
Stack dump:
Regards
John
geposted Tue 02 Dec 03 @ 4:53 pm
Please try to reinstall Virtual Dj
geposted Tue 02 Dec 03 @ 4:59 pm
Have unloaded and relaoded a couple of times with the same result.
I also get the fatal error report screen. press 'recover' and it dissappears. Illegal operation 0187:0044e6af
geposted Fri 05 Dec 03 @ 3:39 pm
try:
1 - Uninstall
2 - Delete the virtualdj folder
3 - Run regedit and delete the key H_KEY_LOCAL_MACHINE\\SOFTWARE\\VIRTUALDJ
4 - Reboot
5 - Close all programs in background (antivirus)
6 - Reinstall
FRUiT94
1 - Uninstall
4 - Reboot
6 - Reinstall
FRUiT94
geposted Fri 05 Dec 03 @ 3:47 pm
virtual dj is asking me for a serial number but i dont have one wat should i put in plz help me
geposted Sun 07 Dec 03 @ 12:32 am
alibook2000, buy the complete version and you will have a serial number..
Coyote
Coyote
geposted Sun 07 Dec 03 @ 12:58 am
Thanks Fruit for the suggestion.
Unfortunately it had no effect. Failed as normaal.
Is VirtualDJ ok with DirectX 9.1/Win98?
geposted Tue 09 Dec 03 @ 1:03 pm
I think vdj has problems with Win98, especially with cd audios reading, and maybe more....
FRUiT94
FRUiT94
geposted Tue 09 Dec 03 @ 4:51 pm
Definately sounds more like a windows error than a VDJ error.
I know you probably already have, but double check all current drivers for all parts of your computer...
all available windows updates too...
geposted Tue 09 Dec 03 @ 5:04 pm
"all available windows updates too... "
The only problem wuth this is Microsoft does not support that Windows Platform any longer, They only support Windows 2000 Pro/Server And Windows XP Home/Pro and of course 2003 .NET Sever. Meaning that allthough you might find something on TechNet, it will most likely be a few years old. As they do not provide new Tech service or patch updates any longer. Best advice if updating your drivers does not work is update your Operating System.
Regards;
Redman247
Regards;
Redman247
geposted Tue 09 Dec 03 @ 5:47 pm
where to find the updates for virtual dj to run on xp?
plus do i need to update the program?
geposted Wed 13 Oct 04 @ 10:39 pm
galate2: the update is available here:
https://virtualdj.com/purchase/
Your 1.02 version is really out to date...
geposted Fri 15 Oct 04 @ 2:55 am
hehehe :o)
geposted Sat 16 Oct 04 @ 10:42 am
I'm so frustrated! I've downloaded the trail version, but it wont load, windows comes with an error saying: DINPUT8.DLL has not been found. I've tried re-installing etc
I'm jealous because my mate has VDJ and it looks great.
Can anyone help??
My specs: Dell inspiron laptop, Pentium 3 (700 mhz), 128 mb ram, 10 gig hd.
Can anyone help??
geposted Mon 18 Oct 04 @ 9:48 am
download the latest version of Direct X and this *should* solve your problem
geposted Mon 18 Oct 04 @ 2:48 pm
