Hi All,
I am looking for an audio gate transformer/effect. I want to be able to control the length of the drop (1/4,/1/2, 1/16, etc.) thru the hardware The current mapping controls the current controls the strength. This description is in Cut effect terms. I have a Prime 4+, I haven't been successful in re-mapping because I am concern that will impact the behavior of the Prime 4 for all effects rather than just that effect when I call it in any of the deck. any suggestions on effects? In Traktor was called Gate.
geposted Tue 11 Aug 26 @ 9:13 am
If windows a virtualfx can act as a proxy control and you can swap dials.
Although the hardware mapping isn't difficut
just query if effect_select returns "cut", if yes effect_slider OTHER_ONE, if no stay normal
geposted Tue 11 Aug 26 @ 9:52 am
Bear in mind also that the deck FX in VDJ can be switched between single slot and three slots, meaning that (in three slot mode) each of your Prime 4 FX knobs controls parameter 1 of the three FX slots.
In single slot mode though, if you have CUT loaded, then knob 1 controls param 1 and knob 2 controls param 2 (Length).
geposted Tue 11 Aug 26 @ 10:35 am
