After the latest VIRTUALDJ update, the file counter in the browser status bar (which used to show the number of files with the label "FILES" next to it) now displays "IFILES" instead. This happenswhen browsing any folder. Has anyone else noticed this, or is it a known bug? OS: WINDOWS 11, VIRTUAL DJ PRO
geposted 3 hours ago
It means you probably have an outdated language file in your VirtualDJ\Languages folder
What does that mean (i.e. in what way can a language file become "outdated")?
When it's missing newer translations, such as "IFiles" in this case
I just looked at my language file and I have an ifiles tag, which presumably is the way the quantity is now displayed (the quantity being %i). When did that that get added/changed, and what else might be missing? I see there are several things that use %i
In other words how is a user supposed to know what to update?
geposted 2 hours ago
Don't think I've ever seen anything in the changelogs about language files.
My one dates back to August 2014
geposted an hour ago
geposted 57 minutes ago
OK so after the user does all that stuff (downloading languagediff etc) then any new things that have been added to (presumably) Greek.xml will have "update=" added. The user then has to manually edit the xml file to enter the new text in their own language?
geposted 19 minutes ago
Indeed
geposted 15 minutes ago
