Topic: Sampler problem
VirtualDJ versions 2025 and 2026 have a problem with the Samples section, and you still haven’t noticed or fixed this issue after two years.
When you load a song and trigger a sample, there is no problem as long as the previous song is still playing, even if you mix it with another song. However, as soon as you stop the previous song and change the tempo of the next song, the sample goes out of tune and loses sync with the beat.
This problem occurs when the software is connected to a controller.
You haven’t fixed this issue for two years.
I want you to fix this problem as soon as possible with an update.
geposted 3 hours ago
