Topic: Why does the user interface contradict itself?
I'm using a Pro skin:
If the pads are enabled in default mode, then the pad name is turned off.
For example, “Stems” indicates that it is disabled.
But if I select the 4btn mode, then the “Stems” tab is highlighted in color.
How then can I tell whether the “Stems” function is enabled or disabled?
geposted 2 hours ago
