HI,
when I'm using Color FX Loop-Roll, and in between press a Cue Point, then VDJ does not jump in sync to the new point. By chance you hit the right moment, but often it creates a small stutter if not perfectly on point of a beat.
I think that was better in later versions, but I have no chance to test that out.
Anyways it would be great if cue jumps could be set in sync to loop roll, so an active loop roll should not change when pressing a cue button.
geposted an hour ago
