Fantastic option for experienced users
VDJ continues giving options to the people!!
geposted Fri 18 Sep 26 @ 11:43 am
I’ve run into something with the new 'Shoutout' feature that seems like an oversight. When a shoutout is saved to the sampler, it correctly keeps the selected 'Style' and 'Voice', but it doesn’t retain the chosen Talk‑Over mode. In my case, I’m using 'Stems Swap', and once the shoutout is saved as a sample, that Talk‑Over behaviour isn’t applied on playback.
Unless there’s a setting I’m missing, it looks like Talk‑Over isn’t stored as part of the shoutout’s metadata. The only way to recreate the behaviour is by using a deck and manually applying Stems Swap, or by scripting a workaround.
Just wanted to bring this to your attention — having Talk‑Over modes saved along with shoutouts would make the feature more seamless for live use.
geposted Fri 18 Sep 26 @ 2:19 pm
the SOUND INSURGENT wrote :
used this and it launched the sampler lol!
locoDog wrote :
script is
shoutout
the definition hasn't been updated so it won't autocomplete currently.
shoutout
Creating a custom button, using "shoutout", didn't work a few days ago, got a mic talk over, today tried again using "shoutout" it worked perfect... thanks
geposted Sat 19 Sep 26 @ 7:56 am
That's because we do read to what's posted on the forums ;)
By the way, additionally, there's a new EA build now (b9642) that adds a "ShoutOut..." entry in the menu of the sideview sampler, for people who are using a custom skin without custom buttons.
Selected as best answer geposted Sat 19 Sep 26 @ 8:34 am
Hi Stephane
For all the euphoria, you shouldn't forget the mistakes made so far.
The "search_playlists" command still yields only sporadic results.
geposted Sat 19 Sep 26 @ 9:04 am
Benz Werner wrote :
Hi Stephane
Perhaps it got lost in translation, but that didn't read politely. This is fresh beta software, not a year long issue that hasn't been addressed. I'm sure this will be fixed in due course.
geposted Sat 19 Sep 26 @ 10:03 am
Benz Werner wrote :
Hi Stephane
And this is not the place to be bringing that up - there is a dedicated post you made for that, so please continue that discussion there.
geposted Sat 19 Sep 26 @ 3:15 pm
Just a suggestion for the Shoutout feature. Add an accent feature, such as European and British accents. For example, a female English accent is very sexy and would work well for club DJs.
geposted Sun 20 Sep 26 @ 10:58 am
uh... would depend on the venue on that one.
geposted Sun 20 Sep 26 @ 2:15 pm
Using Shoutout for the first time live today, with music playing, I'm finding the volume a little low.
Even using the talk-over volume dipping option, there's not quite enough output IMO.
I think there may be some variation in level of the generated voices as well, which doesn't help.
Any chance of giving it a bit more gain, or maybe adding a maximizer/normalizer?
geposted Sat 26 Sep 26 @ 7:24 pm
+1
geposted Sat 26 Sep 26 @ 9:00 pm
What Sebastian said is when you save a shout out as a sample it doesn’t sample stem swap like normal samples do. Anyone got any ideas? Or is this a current limitation?
geposted Fri 02 Oct 26 @ 7:32 pm
That was my question to, here..
https://virtualdj.com/forums/270283/VirtualDJ_Technical_Support/Shoutout%21.html
geposted Sun 04 Oct 26 @ 10:39 am
