Today, I realized that all waveforms related to all tracks I have are shifted, i would say around 1/2 a beat.. Like all wafeforms have a new and same value offset on screen (for example sync works on t tracks).
If I apply BMP analyzer on a single song, it is not correcting the error, while up to 2 days ago it was perfect.
I am using VD 2026 part 3, I din't do any changes on options.
Has anyone faced the same issue?
Thank you
Paolo
Thank you
Paolo
geposted 4 hours ago
What's shifted ? The audio ? The CBG ?
Due to urgency, I decided to go back to previous version b9598 and now it seems ok.
My impression is that it was a visual issue, I mean, my hot cue were still on the proper waveform beat pick but the sound of the beat was coming "late", on all tracks. that's why for example sync worked.
A relief to see it works now because I have an event tomorrow, but I'll try to investigate more reinstalling the new version next week to see if I can replicate it.
geposted 3 hours ago
When audio comes late on all tracks, that's usually an indication of high audio latency.
Depending on your system this could be due to several reasons, but usually a system should not have different latency between two program restarts, or even between different versions.
Maybe you used the wrong sound setup ? Maybe you used a VST plugin with high latency ?
Maybe something else entirely.. But the first thing you should check is your audio drivers and buffer configuration.
