I was wondering if anyone was aware of a glitch with Pulse DJ AI causing Virtual DJ to close without warning mid song? It happened to me twice in live situations and I just uninstalled Pulse DJ on my M4 MacBook Pro. Now I cannot replicate the close without warning no matter how hard I try.
The thing I cannot get is was it a Pulse/Virtual glitch or was it because I forgot to disable sleep on my Mac's USB ports? I'm hesitant to reinstall Pulse to try because it was a CHORE to remove! It leaves a startup script in a hidden spot and every time I fired up Virtual DJ, I received an error that it could not find Pulse DJ at startup.
geposted Mon 21 Sep 26 @ 8:13 pm
Sounds like a bug you need to file with Pulse DJ devs.
Atomix is most likely primarily concerned with VirtualDJ and its official application connections - pretty sure Pulse DJ doesn't fall under that category currently.
geposted Mon 21 Sep 26 @ 9:53 pm
I get it. I was mainly wondering if anyone else used the software and had the issue. Now that I have uninstalled it, I have no problems.
The only errors in my VDJ log file came from using Lexicon to remove duplicates on a backup hard drive that caused database corruption. That was easily resolved by rescanning the drive in Virtual DJ.
geposted Wed 23 Sep 26 @ 10:04 pm
