Hi all, i'm picking up after 10 years not haveing played DJ again and i got really confused on the POI and analyzing. I excpected when analyzing VDJ would also create cue points for me (Start, 1st drop, ending, SOS loop etrc...) but i can't seem to get proper response. Must be me for sure...
What I want is my pads "HOtcues" to have the cuepoints. I read a lot about it now being automix but that options does not fill my pads to use them and neither can i find these created automix points. So basically how can i let VirtualDJ create the hotcue points and use the pads to trigger them...? I know i can do it manually but i like some batch solution. Any tips or guidance?
Thanks in advance. Copilot seems to mix responses from the last 20 versions :-)
(PS: I use LexiconDJ which generates and exports cuepoints to VDJ if i want but VirtualDJ should be better at it). When exporting from LexiconDJ the cuepoints are exactly where i expect them on the pads HiotCues.
geposted 4 hours ago
