Topic: CUE action for shader active
Hello everyone, Virtual DJ 2026 has done a brilliant job, and it’s only fair to say so. I’ve been using shaders in animations for a while now. I’m trying to incorporate the command into a macro so that the correct shader launches. And, of course, to close the effect with another command.
I’m using the ‘Action’ function, but even with the new AI support, the command isn’t working. Does anyone have an answer, please?
Here are the command lines I’ve tested:
video_fx_select+"Salsa Couple Dancing"
video_fx on & video_fx_select "Salsa Couple Dancing"
video_fx_select "Salsa Couple Dancing" & video_fx on
video_fx_select "v_pMHT" & video_fx on
*Salsa couple dancing is original name on shader list
**v-pMHT is the name in the folder shader list xml (for the same shader)
video_fx_select_shader_file_name"v_pMHT" & video_fx on
effect_active "video" "v_pMHT" on
Translated with DeepL.com (free version)
geposted an hour ago
I'm using :
deck master effect_string "shader" 2 "Paste in the desired Video effect name here"
So in your case: deck master effect_string "shader" 2 "Salsa Couple Dancing" should do the trick.
This will select a Shader or a Video in the "Overlay section". "Visuals" needs to be checked marked in this section.
