Whats the script to record a current playing loop on deck 1 for example (with stems turned on -in this case just the drums- but could also be any stem/s i have playing in loop) to record and instantly play in sampler?
I can only make one ( sampler_rec) that works when all stems are active currently.
Tia
Tia
geposted Sun 04 Oct 26 @ 9:42 pm
loop recording doesn't capture the sound, it captures from the file, to capture with stem cuts you need to sample record start record stop
geposted Mon 05 Oct 26 @ 10:43 am
Thanks LD i did manage to record just the playing loop (with the stems tinkered) by changing the sampler trigger settings although it was a complete fluke lol
I will try your suggestion.
Also and forgive my uselessness when scripting, im trying to map a toggle button on controller for a specific sample bank for sampler fx on - but can get it to turn on but not toggle (ive tried putting ‘toggle’ in script) any advice? Thanks
geposted Mon 05 Oct 26 @ 10:55 am
what do you have now? because what you're aiming for isn't clear with what you've described thus far.
geposted Mon 05 Oct 26 @ 10:58 am
Im not in to show right now will post later- but from memory i think its ‘ sampler_bank "Your Bank Name" & effect_active 'sampler'
geposted Mon 05 Oct 26 @ 11:28 am
