Hi,
Hopefully an easy fix to this, but thought I'd ask if anyone else has the same problem.
When using timecode as digital vinyl is the deck select button meant to allow you to control which ever deck you select? It doesn't for me and I feel like it should. It changes the pads to the correct deck but the timecode doesn't change with it.
Any thoughts?
Thanks
Bryn
Any thoughts?
Thanks
Bryn
geposted 2 hours ago
