At least I could show two pannels at the same place. Stills few questions:
1) when the skin loads, it doesn't show the pannel that has the visible="yes" property. When it loads, it show the buttons properly, but not the background. All the controls are contained in a "blank" area. After the loading, I switch to a pannel, and the problem is solved.
2) When I hit a "show_pannel" button, and re-hit again, the pannel's background disappears, as if I loaded the skin ("blank" area).
3) When I modify my skin's files, and reload the skin to see what happen, and then hit the "pannel" button to look at my work, VDJ crashes with the recovery dialog box. it often appears, sometimes 10 times a round.
Considering 1) and 2) I CAN'T submit a new skin because the result when the skin loads is too ugly. After a conversation with Dj Speedland, it seems that the xml is correctly written. However if you ask I can send you a copy of the skin to look at it.
Am I missing something? Or is it a known issue?
FRUiT94
FRUiT94
geposted Tue 02 Dec 03 @ 12:33 am
the same issue for me :-(
Gwenn
Gwenn
geposted Tue 02 Dec 03 @ 10:04 am
could anybody confirm or explain? Dev Staff? Jim Nordic?
FRUiT94
FRUiT94
geposted Wed 03 Dec 03 @ 6:27 pm
geposted Fri 12 Dec 03 @ 1:24 pm
Please please for the next release!
Please add the pannel property to the scratch. Why can't it be in a pannel? Is there a reason? Please add it.
FRUiT94
FRUiT94
geposted Fri 19 Dec 03 @ 11:32 pm
I also noticed that we couldn't put comment tag in the file xml.
like: <!-- Crossfader -->
why?
Gwenn
why?
Gwenn
geposted Tue 23 Dec 03 @ 10:13 am
