Topic: where is the Bar Counter option?
It seems like there is a bar counter option. However, I just can't find it.
I apologize if this is trivial. There's so many options in VDJ, the learning curve is a bit steep.
geposted an hour ago
If you mean these you set it in the Layout menu to the left
Yes, that's the one, thanks. I guess that is skin dependent and not available everywhere? I was also trying the blocks skin and there I can't see the option.
Actually having each bar labelled is not an option though, right?
Another thing I haven't figured out, is how to increase the font size in the interface, only in the browser.
Thanks!
