Topic: help with script for pitch 100%
Hello, on my controller I have two Pads for sync.
One syncs leftdeck to rightdeck and vice versa.
The Pad-LED should blink, if pitch isn´t 100%.
Strangely enough, one of them is always flashing, even when BOTH Decks are set to 100% pitch.
But only if PITCHLOCK is activated.
How can both LEDs stop blinking if pitch is 100% without deactivate PITCHLOCK?
Thank You for any Ideas
Greetings
Svenino
LED Script:
deck left pitch 100% ? color green : blink ? color green : color 10% green
and the same for right with "deck right".
The Script for Syncing when holding (and pitch reset) is:
holding ? deck right masterdeck & deck left sync & pitch_lock on : pitch_lock on & deck left masterdeck & deck left pitch_reset
And the same vice versa for the other Pad.
geposted an hour ago
