Topic: Bad scratch if "JogSensitivityBend" is enabled.
I’m doing a scratch on the controller (map JOG=touchwheel , JOG_TOUCH=touchwheel_touch)
It’s also easy to check without a controller, using the mouse on the skin’s wheel.
I feel that the bend and touch are conflicting. I checked it this way and made sure:
options -
touchWheelBackSpin =yes
touchWheelForwardSpin =yes
JogSensitivityBend - increase the value ( for example =10)
PLAY track.
Make a forward scratch and release the wheel (or forward spin) - The wheel will stop, but then wavetrack will resume movement for a few seconds.
However, scrolling Backspin scratch doesn’t conflict and stops immediately. And it plays normally
geposted 36 minutes ago
Even if you turn off “JogSensitivityBend” = 0, it still affects the slow movement of the scratch.
This gives the sound a smeared, blurred quality, like the first old CDJ‑1000s. The scratch slow and sounds digital.
