First off.. kick ass program.
OK heres my situation... i have a MonsterSound MX300 running under Win2000. Since its a 3d sound card i set the sound options to use the speakers and the headphones... problem is that when i listen to the head phones i hear both songs playing at the same time... no matter what.. also sounds very gargled.... any clues as to why this is happening...
geposted Sat 07 Apr 01 @ 1:50 am
This feature is only available in the full version. If you use a crack, it won´t work. There is no crack out there making AtomixMP3 fully functional.
geposted Sat 07 Apr 01 @ 7:26 am
The solution is simple..........
Firstly get the full version of Atomix.
Secondly buy a second soundcard. (eg, SB Live)
You see I also have a MX300 its a great card but if you wan't to get the full use of the headphones you really need two soundcards. What I did is I bought a SB Live, so then I could play to the crowd (or whoever) through the SB Live, and monitor through the MX300 !!!!
EASY (and it works well)
geposted Mon 09 Apr 01 @ 2:36 pm
Well i have the full registered version... not cracked or anything.. its legit.. and my buddy does too.. and he has the same card.. and it works for him .. but the only difference is that hes running WinME .. im running Win2K. I really dont wanna have to buy another soundcard.. and installing anything other than Win2K is not an option... any other ideas as to why it doesnt work. I mean if its comes down to it i might as well buy a second sound card.
tRENCH (author of the anonymous post above)
geposted Tue 10 Apr 01 @ 3:15 pm
All those 8830 like :
Aureal VorteX 2
Diamond MX 300
Turtule beach Montego
and many others...
Will not let u use real jack to output second deck...
No problem... sound sux with that output anyway.
If u use Win2000 then buy another Aureal 8830
Go with beta driver @ www.vortexofsound.com
those 2 cards works fine together win2000 and whistler
BUT!!! Only 1 Soundcard Must be installed to setup the OS!
Plug the other after updating the driver of the first card.
2 8830's are the best combo i used till now.
I think the best maybe M-Audio Delta44 but it costs...
If anyone has prob with sblive and Whistler...
Install Liveware3 for win2000 driver AND The Full Liveware
it will work.
Anyway if any has the basic skin of the 1.2...
please send... i'd like to work and more skins...
Aureal VorteX 2
Diamond MX 300
and many others...
it will work.
geposted Wed 18 Apr 01 @ 2:52 am
