Topic: Min. Requirement for v.1.2
Can you tell us what the min. requirement will be to run the next version of atomixmp3? Or are you still trying to figure that out in the beta testing?
It would be nice to know if I need to upgrade my computer.
(PII-366 196MB Win2000)
- Jim Nordic
geposted Mon 06 Aug 01 @ 1:32 pm
It should work ! The next version will be more optimised than the current one. So if the 1.12 works great, the 1.2 should works without any problem.
- Dams -
Jim, old boy, what a silly question. You know as well as I do that you need to upgrade your computer just to run v1.12 effectively. I recommend a NASA supercomputer, that should just about do it.
Anyway, apart from that, these are the other minimum requirements:
Ability to hear.
One hand, two an advantage.
Vision, preferably two eyes.
Oh yes, and about two years of patience. Thats how long it will be till the new version is released.
Glad to have been of help. No thanks necessary.
