Can anyone explain to me what that means??? Seems that everytime i complete a mixed session on wave format, and i try to play it back on winamp i recieve this message: Missing FMT chunk, and i can't play it back because it is not wave supported.
Help please. Thanks. MKJ
geposted Tue 14 Aug 01 @ 4:36 am
The FMT chunk is the "container" where the wave data is saved in. It contains the information where the file begins, where it ends and how long it is.
If it is missed, the recording was not ended properly. If you record with AtomixMP3, be sure you click on the record button to end the session, before you shut down AtomixMP3.
To restore the wave, you can find some information in the german forum or in the web. You need to edit the file with a Hex editor.
mama
mama
geposted Tue 14 Aug 01 @ 8:38 am
Thanks for responding that helps alot.
MKJ.
MKJ.
geposted Wed 15 Aug 01 @ 5:33 am
Here is a little app to do the work for you. It is in german, doesn´t work with W2k and doesn´t support too big files, but it´s worth trying!
http://members.nbci.com/_manuela_/download/waverett.zip
mama
mama
geposted Wed 15 Aug 01 @ 8:21 pm
