Hi there,
1. i can`t find the option for the DSP-Plugins. Are they gone?
2. I would appreciate, if you could build in a shoutcast-connector!!!!!!!!!!!!!!
Thanx!
Do you plan this in the next update???
As you can read in several forum sections, many people are asking for this and it is important for them!
cu
Mark
Thanx!
cu
Mark
geposted Sun 02 Dec 01 @ 2:18 pm
There was a little poll about the plug-ins in the forum... and now the plug-ins left atomix. i think because most of them didn't work correctly.
Desruptor
Desruptor
geposted Sun 02 Dec 01 @ 2:36 pm
I had the same question as you. Here the poll:
http://www.atomixmp3.com/forum/display.html?forum=3&topic=2739
geposted Sun 02 Dec 01 @ 11:29 pm
You don't need shoutcast built into AtomixMP3, it'd be a waste since it's reallll easy to just run under winamp itself.
Install the plugin (shoutcast) in winamp, get it all working... Then simply clear the winamp playlist, activate the plugin under winamp, use your audio setup to connect your main output back into the linein of your soundboard, and shoutcast directly from the linein...
Basically, you just run winamp only to start the shoutcast plugin... then have shoutcast get it's audio from your linein, which you just connect to a record output of your amp/mixer/reciever or make a splitter cable to feed the audio out back into the line in.
This works great for me. I commonly use it to broadcast.
-Nate
-Nate
geposted Mon 03 Dec 01 @ 12:03 am
