After messing with the new version of atomix, it sure does work alot better than ejay did...
A few things you guys might want to take into consideration on changing...
The file list is WAYYYY slow and clunky when scrolling thru files... also, you guys should either remove the playlist option from the list or make it so when the panel is locked it wont scroll either way and not just prevent it from scrolling to the left/right exposing the playlist option.
This is very annoying as it becomes a game of catch the scroll bar if you go to far over when moving the mouse.
Other than that the only thing i could suggest is work on the optimization to make the program run a bit smoother and add advanced effects options (such as level and amount).
-Noah
-Noah
geposted Sat 08 Dec 01 @ 7:31 pm
You can lock the playlist window, then drag it to the left to keep it out of sight entirely....
geposted Sat 08 Dec 01 @ 7:50 pm
Thanks for the tip of the playlist... I probably never would have noticed!
-Nate
-Nate
geposted Sat 08 Dec 01 @ 9:53 pm
