I think it would be better if we could change live the loop length(from 8 to 4 beats for example). I dont know if this is possible and I believe its essential for mixing. I'd like also to have more loop length choises(from 1/8 to 8 loop length would be perfect)
geposted Mon 10 Dec 01 @ 6:04 pm
Just wait for the new v2.1, it should be released soon now :)
geposted Mon 10 Dec 01 @ 6:45 pm
WOWEE!! 2.1 already? I think the team is getting the idea of this whole update thing! Just kidding guys, you're doing a great job. Already we're seeing the awesome power and expandability of your program! Thanks again!
the Goner
the Goner
geposted Mon 10 Dec 01 @ 6:50 pm
Also,pleeeease put a fetaure so you can change when automix crossfades automatically. I've found that it crossfades way too early, and I know that I can't change that.
geposted Mon 10 Dec 01 @ 6:54 pm
hé hé hé!
we have promised to try to release new updates asap now.
As you can see with the effects addons, or skins adons, or wallpapers we try to make little updates now to release new versions quickly. Of course, you will not see a new default skin with new features in all next versions but we will try to keep "a good rate of release"!
In fact, we are now waiting the final version of the 2.1 in order to check it before releasing it!
our servers will be one more time overloaded
geposted Mon 10 Dec 01 @ 8:07 pm
Would it be to hard to ask for an option to save the loop points.
thanx
thanx
geposted Mon 10 Dec 01 @ 9:49 pm
