i burned some cds from my collection onto the computer and when i go to load them in the virtual dj they wont even recognize the tracks, there not from the internet, there actual bought cd singles, any way i can fix them so they can be loaded? thanks get back to me.
geposted Mon 08 Dec 03 @ 8:58 pm
what bit rate did you encode them at ? Are you sure you are pointing VDJ in the right direction of the tracks. Be sure you are grabbing the tracks from the folder where you copied them in to. Also try rescanning your hdd if you have moved them.
geposted Wed 10 Dec 03 @ 9:28 pm
