i have the version 2.0 but when ever i try to change my skin i always get the eror with some kernel guy.
can enyone help???
can enyone help???
geposted Sat 20 Apr 02 @ 3:02 am
Download V.2.1 !!
Bye,
DJ Coc "Argentina"
Bye,
DJ Coc "Argentina"
geposted Sat 20 Apr 02 @ 4:55 am
you can only use 2.0 skins on version 2.0 , and 2.1 skins on 2.1 so on otherwise all the functions wont appear on 2.0 skins if u have version 2.1 ... any how down load the skin and open your folder.... go to "my computer" and find "programs" , find atomixmp3 folders and under skin folder drag and drop the skin( has 2 files ) into the atomix skin folder...close all the folders and load up atomixmp3 program... under options change skin ...your new skin should be in there.... Dj one pak ... enjoy......
geposted Sat 20 Apr 02 @ 3:45 pm
All the skins are more than 800-600.
why?
i cant find any with 800-600.
I tryed the v.2.1 but same thing
why?
geposted Sun 21 Apr 02 @ 1:40 am
Download "Greece pro" skin.-
Bye,
DJ Coc "Argentina"
Bye,
DJ Coc "Argentina"
geposted Sun 21 Apr 02 @ 5:33 am
