Can I use the console with other soundcards in the full version, like an stand-alone external controller.
Meaning : the console is only plugged in via usb and no audio out connections from the controller. The actual sound comes out of the existing sound cards.
This would ideal for me because I have two sblive set-up and working perfectly, so I wont need to switch cables everytime I want to use the console. If so, i'm gonna buy this prog !!
geposted Wed 10 Dec 03 @ 9:54 am
Yes, you can do this with the Full Version :)
geposted Wed 10 Dec 03 @ 12:55 pm
as justin timberlake would sing :
"tadadadadaa.... i'm buyin it ...tadadadadaaa ;-)"
yihaa, another vdj user.... now hoping they proces my order asap. Can't wait.
-Respect to the VDJ crew/developers-
geposted Wed 10 Dec 03 @ 5:27 pm
Ah, but has the full version support for the DJ console, ie does it respond to the USB commands ??
Jason.
Jason.
geposted Fri 12 Dec 03 @ 12:27 am
yep.
Choose Hercules(w/inverse pitch and "stickscratch"), Midi, DMC1/DAC2 or the XP10.
All alternatatives can be "ticked" at once too, maybe you can use 'em all at once. Or XP10 for playback controls, and a midi keyboard or controller separately to run fx, samples and special functions. Guess that's the point of a FULL version ;o)
geposted Fri 02 Jan 04 @ 7:12 am
BUT I can't get the sound through the DJConsole configured correctly with Vdj 1.08 full...
What I'm trying to do is map cue/pre to the Headphone outlet in the Hercules console.
Guess this is a special mapping in the Hercules version of Virtual DJ.
It's no BIG problem - guess it'll run fine in Hercules 5.1 mode, 4.1+mixtable in audio setup and my Numark for cue.
Hooking it up later.
Guess I can always use the included Herc. vdj version for "off set" cueing..
geposted Fri 02 Jan 04 @ 9:30 am
how do you open sound configuration on the full version of virtual dj 2
geposted Wed 21 Jan 04 @ 9:23 pm
