i have the new labtop sony vaio grx 550
if you know someone that has it or is working with it
i would like to know how good is it going
my problem is the i have a 30 gigs harddrive and i have like 25 gig full of music
i love atomixmp3 v2.1 but is not working correctly
what sould i do whem i play a song it skips like a cd
it is not fun to play on a club and have that kind of problem
thank for your help
thank for your help
geposted Wed 08 May 02 @ 10:50 pm
yes i have the original version 2.1
i love atomix
but it really sucks that i bought one of the best computers and is not working right
i love atomix
geposted Wed 08 May 02 @ 10:52 pm
i love atomix
i love atomix
i love atomix
i love atomix
You might check to see what you have running on the laptop in the background. Look beside your clock icon in the tray and see how many other icons you have beside it. Try shutting down everything but systray and explorer in the task manager (ctrl-alt-del) one time. and end task on anything other than the programs stated above. Hope this helps.
geposted Wed 08 May 02 @ 11:15 pm
man i check that out already
do not know what to do pliz help
geposted Thu 09 May 02 @ 1:03 am
what system are you running and whats the ram on that,any other options lan stuff like that type it here and the sound card too
NaDeR
NaDeR
geposted Thu 09 May 02 @ 3:58 am
Hi
25g of music on a 30gb hard drive doesnt leave much room for your o/s and any other programs !!
It may be your swap files are fragmented all across the drive.
Please post more info about your system
o/s,ram etc and how much free space is available on the drive?
STU
STU
geposted Thu 09 May 02 @ 10:10 am
GO TO SYSTEMS AND CHECK YOUR HARDRIVE SPACE AND MEMORY RAM , I RECOMMEND A RAM GREATER THAN 128 MB AND AT LEAST 50 PERCENT OF DISC SPACE TO RUN THE ATOMIXMP3 WITH ANY PROBLEMS, BUT LIKE THE GUYS SAID EARLIER, WHAT'S YOUR LABTOP RUNNING????? MORE SPECS......
THANKS DJ ONE PAK
THANKS DJ ONE PAK
geposted Fri 10 May 02 @ 3:49 pm
