i am runnin version 1.12 and i need some question answerin please
1) what is a dsp plugin and why wont the effects pplugin work
2)how do i hook my mixer up to my soundcard (awe 32)
3)does any one no any effects that create the effects of the pioneer cd dj 100s
many thanx
many thanx
geposted Sun 12 May 02 @ 7:47 am
Hey, Download 2,1 !!
geposted Sun 12 May 02 @ 9:19 am
If you have 1.12 unfortunately none of the effects or soundcard issues will be supported. Where did you get this version 1.12 at. If you purchased it legitametly you should be able to get the update : )
DJ Homeboy
DJ Homeboy
geposted Sun 12 May 02 @ 9:33 am
HHmmmm 1.12? That was 2 updates ago. If you actually own it you can upgrade it for free. If you don't own it, don't come around here asking for help. Figure it out yourself. You'll find the Atomix team to be very helpful once you own the program, they're even very helpful if you are using the demo. The software is only 60 bucks, just to upgrade from 1.12 to 2.1 is more than worth the money. Either buy it, or download the ligit demo, or go away!!
thanks for stoping by.
geposted Sun 12 May 02 @ 3:37 pm
