man i did all you told me, but when i get to
If it is not set to 1 click on EnableUDMA66 and change 0 to 1.
i do not find EnableUDMA66 to change it from 1 to 0
i thing i get looss
i do not see it
i run win xp pro
and last question wich operator system you thing is better to use atomixmp3
thanks for all the help
i am finally getting close to be able to use this smolle progam to work right in my grx 550 sony vaio
(but still i should nat have any problems )
i thing i get looss
i do not see it
i run win xp pro
geposted Wed 15 May 02 @ 7:36 pm
Hi,
well first you must set EnableUDMA66 to 1 and not to 0.
0 is default but then you have only UDMA33 wich have slower
data transfer from your Harddrive.
I use winXP Pro as well and the option EnableUDMA66 is there.
If you start the Regeditor you can go to to Edit and search for EnableUDMA66. The Searchfunction should find this option.
WinXP (Home or Pro) works great with atomixmp3 and is very stable. I Think it's the best OS Microsoft ever made.
greetz,
Janosch
greetz,
Janosch
geposted Wed 15 May 02 @ 8:47 pm
tyank you dj yayo'
geposted Thu 16 May 02 @ 12:03 am
