ANY HAS THE 2.1 PATCH? I ALREADY HAVE 2.0........ AND I CAN'T UPDATE IT ON THE SITE...COULD U SEND IT TO ME.
geposted Fri 17 May 02 @ 2:44 pm
there should be no reasonwhy u cant get the update...
the most logical reason is that u have the warez version of atomixmp3 v2...
and it uses a hacked serial...
geposted Fri 17 May 02 @ 7:52 pm
If you are having a problem updating Atomix to the latest version you need to contact support@atomixmp3.com and they will be able to help you with your problem.
V
V
geposted Sat 18 May 02 @ 8:46 am
