Does anyone know if the calculated BPMs are portable to other apps? In other words, are they added to the ID3v2 tags? Thanx!
geposted Fri 31 May 02 @ 2:45 am
speak to the pros... i dont think so but it would be a great idea! there is a atomixmp3 winamp plug-in, which is a bpm counter.
geposted Fri 31 May 02 @ 11:14 am
myeah, but the values it calculates are always 0.3 - 0.4 ... wrong ... in other words it counts too slow ...
geposted Fri 31 May 02 @ 11:19 am
it can be directly downloaded here ...
AtomixBPM
(to the team, i simply tested if the forum would support HTML ... to make the link clickable ... if you don't like this you may modify it ...)
Regards ...
AtomixBPM
Regards ...
geposted Fri 31 May 02 @ 11:27 am
and it doesn't support html links :( ...
but you can find it here --
http://www.winamp.com/components/download_component.jhtml;$sessionid$JWN4HBDFDS4U5TN241HRCZI?filename=http%3A%2F%2Fftp.winamp.com%2Fcustomize%2Fcomponent%2F2001%2F2%2F21%2FP%2FAtomixBPM.exe&componentid=47128
copy paste in browser window ...
Greetz
Greetz
geposted Fri 31 May 02 @ 11:28 am
One thing is 100% sure.. Atomix doesn't even support ID3v1 so getting Atomix to update the ID3v2-tags is not gonna happen any time soon :oP
geposted Fri 31 May 02 @ 1:14 pm
