Whether it is possible to save own mixes in any format, except for wav for economy of a space ?
geposted Sat 01 Jun 02 @ 12:45 pm
only wav files are supported for the moment ... but you can convert the wav file after recording ...
you can use EAC (www.exactaudiocopy.de) for instance ...
greetz
greetz
geposted Sat 01 Jun 02 @ 1:22 pm
..recording to MP3 or something like that tends to steal alot of your RAM since it basically records in wav/raw-format and then encode it when you stop recording...
I've looked all over but I haven't found any program that can record to MP3 in realtime, probably due to the fact that the MP3-encoding process can't be done in realtime.. :oP
geposted Sun 02 Jun 02 @ 2:43 pm
