Topic: Soundblaster Extigy
If anybody was thinking about buying a Soundblaster Extigy for their laptop then I can confirm it is indeed an excellent product and it works fine with Atomix. It uses a USB connection and it is happy to work on a USB hub with a USB IR mouse. Simply choose 4 speaker mode from the Creative Audio Mixer program and select the Extigy as and 3D sound card in Atomix audio setup then away you go.
geposted Wed 26 Jun 02 @ 10:43 am
Does it work fine with NT and XP ? And doesn't it make your PC run a bit slower (do the curve still move OK ?). I heard that USB devices slow down the computer a little.
Well I have a 1GHz PIII with WinME and 256mb RAM and there are no skipping problems or slow moving display problems on my machine. Its actually faster than it was when I was using the internal sound card.
I have the external Soundblaster Extigy for my laptop. What setup and what connectors do i use to get music in the headphones and music from both speakers. I have tried everything to no avail.
