I want to to Sync 909 + 808 (Rebirth) with Atomix.
Its nice to use the hihat & Bass as background beat
But to sync it is not so easy. i think it is nearly impossible
Maybe someone can help me or give some info on this topic.
Best Regards Dj 909
Best Regards Dj 909
geposted Thu 27 Jun 02 @ 10:52 pm
you can't,allready tried unless you get something external like a triton or something else,cause atomix doesnt take an external channel but if they added that feature it'll be great cause i can play beats on atomix while scratching or using a synth or a drum machine on the outside
NaDeR
NaDeR
geposted Fri 28 Jun 02 @ 1:13 am
my god that would be sick.
Take a line in or something...mmmmm
geposted Fri 28 Jun 02 @ 7:27 pm
this would never work.
atomix probably needs to buffer and analyze a second ahead or something to be able to sync...or else, how could it know the bpm and when to sync with next beat?
geposted Mon 01 Jul 02 @ 3:43 pm
redsound makes a device that generates a midi sync signal from audio. It works pretty well, they are only about $179 new as well. however the downside is not device detects bpm perfectly so unless your doing rather boring 4/4 stuff you not going to really be able to do what you wish. Honeslty it would be best to learn to beatmatch atomix to your midi tracks, but its hard of course, but if you can do it then you really have some creative options
geposted Tue 02 Jul 02 @ 9:56 am
