Hello,
I'm sure it was asked before, but I couldn't find it in the forum search.
Last night my internet provider was doing some maintenance, so instead of usual on-line gaming, I thought to mix a little. Double clicked the exe and, as you might have guessed it, nothing happened. I know it connects to the net for updates and stuff, but it was quite an unpleasant surprise, since internet connection is not something that guarantees to be up all the time.
And I'm sure there's a way to turn it off. Being lazy I decided not to look for it myself but ask you guys, cuz you probably know better.
Thank you,
Vlad
P.S. interesting thing, it doesn't work on Win98, but it popped up on XP although after a delay.
Thank you,
Vlad
geposted Fri 28 Jun 02 @ 8:27 pm
Try turning off the
"charts" option in the confg. screen.
geposted Sat 29 Jun 02 @ 8:56 pm
I'm know users who have got this problem even if the chart option had disabled. Personnaly, chart option enable or not, no message from provider.
Try too: service@atomixmp3.com
geposted Sat 29 Jun 02 @ 9:31 pm
