REALLY helpfull towards your peers!! You'll know if you're one and if you are, could you...
please tell me about a "y-splitter".......
Is it software or hardware?.....
Where can I get It?......
$$$'s,,£££'s whatever, how much for it???
Easy to set up??
Do you think Atomix is pure class??
Am I really this stupid?
Amateur user is me, I have the full version running on XP on a decentish machine!
Help, plz!
Thanks for you time, you know who you are!
Easy to set up??
Help, plz!
geposted Sun 07 Jul 02 @ 9:21 pm
I will help you but, you must promise to log in as your registered nick the next time you ask a question. It helps to determine whether or not a user is truley using the full version.
A y splitter is a connection that allows you to split the audio coming from your pc to 2 channels. With the use of this y adapter you can make 1 sound card virtually in to 2. It is very inexpensive and can be purchased from just about any store that carries phono adapters and such. I will fill you in on the details on connecting when you log back in.
DJ Homeboy
DJ Homeboy
geposted Sun 07 Jul 02 @ 9:34 pm
